no fuel spray
atc
please correct me if I am wrong, got fuel to the rail and hear pump run, when I start the car no go. so I pulled a plug and it is dry, shouldn't it be wet with fuel? if so why is not spraying the plugs? I have other post in regards to fuel pump relay/pump bad, but they are working. checked grounds and fuses all seem good. so I thought do the simpe thing of checking spark, and that's where my ? is coming from about the fuel spray.
You were advised to get a noid lite......That will tell you if the inj circuit is actually working......Or not.
They are not expensive. <$20.
I just got a full set for $25 at AutoZone, just ask for fuel injector test kit.
I think you can also use a test light.
I am hunting the same thing on my hot air.
