Mar 9, 2004 #1 A aperrego Drunk? I'll Check. :) Joined Nov 19, 2002 Messages 1,240 Any one give me insight on troubleshooting my Heat? Does not work. I know it goes through the water system.
Mar 9, 2004 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,016 I always check and verify water flow through the heater core first. Assuming the fan works and blows some air. On heat the water control valve should allow water to flow through the heater core.
Mar 9, 2004 #3 T Turbo T/A 1543 New Member Joined Sep 6, 2003 Messages 381 The heater valves on both of my TRs have taken "lazy spells". I'd start there, by feeling the temperature of the hose between the heater valve & the core, if it's not equally warm, manually "help" the heater valve to open.
Mar 9, 2004 #4 6 6SENSE Member Joined Jun 3, 2001 Messages 1,635 Originally posted by aperrego Any one give me insight on troubleshooting my Heat? Does not work. I know it goes through the water system. Click to expand... Can you elaborate? Does the air blow out the vents (blower working fine) but it is cold? Or is nothing blowing out?
