no magic numbers?
jim0207
INVNO1
OTC 4000E
Idle 775-800
open loop
02 Voltage .94
02CC 000
TPS .44
INT 128
BLM 141
LV8 30
IAC 3
Water temp 167
FP Vac pulled 40#
Good bad or just ok?
Have not driven her yet. Just pulled her out for the summer.
blm is hi which means the ecu is adding fuel, some of the scanmaster readings im not sure where the ranges should be myself but blm is deffintly catching my eye
I would put a few miles on it first before taking the readings as gospel. The car has been sitting all winter I assume. Was the battery disconnected at any time or run down? Drive the car and make sure the computer has "Learned" before taking readings.
I did put a new battery in her
