Scanmaster G reading
hangontight
Just hooked up ScanMaster, This is my first time using. Any comments are appreciated.
I had readings for Spark Advance 71.3 & Injector PW of 55.5 This only shows up with ignition on not running( is this correct?)
Below are my numbers, looks like my IAC is high? 10-20 preferred? Any other readings look out of wack?
Turbo Tweak 5.7 chip w/ matching 60# injectors
MV - 796
MAF - 6
LV8 - 43
BLM - 118
Coolant - 169.2
Air Temp - 115.7
RPM - 825-850
TPS - 44 / 4.55 (with ignition on car not running)
IAC 35
02CC - 181
Flags - Park/Neutral / Trans 3rd / A/C Off / Loop - Open
Volts - 13.8
INT 128
