Tim_D
- Aug 28, 2017
Are you sure you have the correct reverse direction pump?
https://www.rockauto.com/genImages/450/HOWTOFREEASTUCKPRESSUREVALVE.pdf
https://www.larescorp.com/tech-tips/flushing-and-bleeding-instructions
Yeah, I saw those two instructional links as well. I performed the "stuck pressure valve" procedure on the first pump, but then I had the same symptoms on the second pump as well.
The Lares part number is 2309, which lists applications only for '86-'87 TR and '89 TTA, so the part number is right. It would be a major coincidence if two pumps, bought 8 weeks apart, were both mis-boxed as CCW rotation.
To me, the symptoms of zero power assist and no obvious flow (as observed in the reservoir) point towards either pump rotation wrong, a stuck pressure valve, air pocket, or blockage... But like I said, I've checked all those items at some point during troubleshooting. That's why I'm extremely frustrated. This is a simple system that I can't get to work!
I guess I have to start over with the stuck pressure valve procedure (AGAIN), bleed the system (AGAIN), and see where I'm at. Time to make another gigantic mess (AGAIN).
