What did you do to get the power distributed?
the possibility of a bad module is at hand, located under the coil pack. first check for spark and fuel delivery. You can pull off a plug wire and put in a known good plug and ground it out. use a pair of insulated pliers if you are going to hold it. then have someone turn the engine over and watch for the spark. if you do, it's not the module. a fuel rail mounted gage is helpful at this point, because while you are looking for spark, you could check to see if you have fuel pressure. It should be 43#s w/ the vacuum line off.
