I've checked all ecm and ign mod grounds to the neg batt terminal....all check out good.Check all of your grounds.
SignUp Now!I've checked all ecm and ign mod grounds to the neg batt terminal....all check out good.Check all of your grounds.
I have similar issues no spark. Change the ignition module and coil pack then got spark but the engine gets stuck when is fixing to star. Change back old module and coil pack engine turns normal. It cranks for a few times then get a spark. I need to be quick on gas pedal and the car turns on and runs like a champ. Turn the car off and everything goes to square one. Any help
Thanks TurboBuRick I reset and start from zero mark then the 25% then find counter clockwise till light came on put everything back. The car started right away.You will need to slightly turn the cam sensor.
Ok, so this will be egg on my face. I lowered my fuel pressure. It was set at around 55 psi line on. Now it's at like 42 line on. Starts every time now, even when up to operating temperature. Must have been flooding the damn thing and couldn't even tell.I have a bit different condition with my GN. I have tried and troubleshooted my way through things and am stuck with a situation where the car will start up on command every time......until it reaches operating temperature. Then it won't restart again until I wait about 1-2 hours. Then it starts up again just fine.
It smells to be running rich also.
Thoughts?? Thanks in advance.
Should be 38 line on if turbo tweek chip.Ok, so this will be egg on my face. I lowered my fuel pressure. It was set at around 55 psi line on. Now it's at like 42 line on. Starts every time now, even when up to operating temperature. Must have been flooding the damn thing and couldn't even tell.
