I just installed a MaftPro, 60lb injectors and an extender pro chip in my car. I also have a LC-1 Wideband and am bybassing the stock O2 sensor
Everything is working cam sensor is sending signal, crank sensor is sending a signal. The coil checks ok on the ohms meter, the ignition control module checks good on the wells tester at autozone.
We are not getting any spark whatsoever. What could be causing this no spark issue? Could it be the maftpro??
I am really lost so any help is apprecited thanks!
