A question for you ignition GURUs. I know this is not a Turbo Car but still is a Buick. A no spark condition and test several things so far. This car was towed to my house because it died suddenly, long story. Now, tried another type2 coil/module,(junk yard part) still no spark, no engine codes, just the 12 code? At the module wire connector, the pink wire gets battery volts during cranking, 12v input. I'm replacing the crank sensor as it both fires the coils and references #1 cylinder position, dual interrupter rings on balancer. The CS, balancer, module was replaced some time ago for the same problem. The balancer isn't damaged, CS doesn't look like any damage to it either. I was told at this point either the module/coil or CS are the culprit. So I'm changing both again. I need to run this car to better evaluate the rest of the car, to keep or not. Any Thoughts? Thanks. Gene
