BARRACUDA1968
- May 4, 2011
Need a little help. Put the new motor in today and when I hit the key to on I have no fuel pressure. My battery is down a little so I charged it for a while. Shows 12.5 volts on the meter an drops to 9 volts when I crank. When I put a load on it with the tester is goes to the low side of good but not weak. I tried my jump box instead of the battery charger with same results.
How much voltage do I need to run the fuel pump?
Is there anything I missed as to why my fuel pump won't build pressure? Ground etc?
I will try a new battery in the morning but I'm looking for ideas on something I may have missed during the install.
Thanks Brett
Thanks Brett
