Lil Truck
I spend to much time here....
- Sep 26, 2002
I am setting up to run the Dry NO2 option. I have a FAST bank to bank system w/fan & Fuel control, I believe it should have 1 stage of NO2.
I have wired in the activation switch to 12v (pink), and the white to neg. side of a relay. At this time the relay is only switching a second fuel pump for testing. The dashboard on the data logger shows the NO2 Enabled but when the perameters are met 75% TPS and 4000 RPM nothing happens, No relay trip or timing Ret.?
Also I have been reading numerous threads on NO2, I am looking for sound advice on my system. I have a Chev 383, H-beam rods, 4340 crank 9.3 Weisco pistons, Dart 200cc ported 2.05/1.6, Holley intake w50lb injectors, NOS 1000cfm TB w/Dry NO2 plumbed, MSD HEI w/MSD 6A, runs out at 6300 Rpm, Small Comp Cam 226/234 520/530, FAST Speed Density w/WBO2 and GM knock sensor, dual 340 fuel pumps.
The NOS dry system is rated 150-200 HP, any susgestions ?
Something I should mention, everything is working great with my system, but at 6700 RPM the motor hits a wall, data logger shows rich, the cam is dead I know, backed out the VE, still dosent rev? Is this normal ? Tried plug gap .035-.045 not much difference. At 36 deg. total, tried 40-32 no signs of knock, but sounds like a mis. ? Adjusted lifters Hyd. several times thought it was pump up. Maybe it is! Never had a Hyd lifter motor act like this.
