JDSfastGN
- Jun 16, 2001
Just wanted to get some ideas before I go tearing in and adjusting pushrods. I just fired up my new engine and am running a 210/215 roller from fullthrottle. I am using Morels from TA performance (purchased before the kits were offered with morels) The car runs smooth but the lifters are very loud as if they aren't pumped up yet. It has about an hour of run time. The exhaust note sounds very strange as well. I am running stock rocker arms and Smith Bros adjustable pushrods. I set them up for around .030 preload with the lifters straight out of the box (I did not soak them) Is that a problem? All my pushrods ended up measuring 8.070-8.093 from end to end. Im also running .060 cometic head gaskets if that helps at all. Oil pressure is good and is around 23 hot idle and goes to 65 under a light load and 3000 rpms or so. Im hoping to have the same results as SNOWBIRD where i go start it in the morning and they are quiet but Im having my doubts haha. Thanks for the help guys.
