I can't answer you question on whether the 87 turbo set up will bolt up to 87 FWD engine, 3.8 I assume? not sure what year the 3.8 block changed for non turbo Buicks,, but if the block is the same, compression ratio is probably higher for normaly aspirated engine, that would be the first problem. The next and bigger problem is even if the block is the same, the cost to convert to 87 turbo set up with used parts is going to start at $1500 minimum, if you're lucky and get package deal from one source. I am just about done converting an 85 hotair turbo engine to 87 set up and am over $2000 in parts! Look in the hotair forum and do search for 85 to 87 conversion, or intercooled conversion, you will see the above prices about average.
Next problem will be getting the transmission to survive. According to you're sig, you are using a VW trans? The FWD Buick trans would'nt survive, and not to sure but the VW may not either. I looked into using Porsche/Audi transaxles with turbo Buick engine and was told by engine/trans adaptor company and others that the Porsche/Audi transaxles did'nt hold up well in customers cars.
That is just a summary of possible problems even if the 87 parts will bolt up, there is a long list of parts,electronics that make up the 87 turbo, again look at the hotair forum for conversion. There is a member here on the board I talked to a while back that has a turbo Buick powered sandrail, you can email him from this board, here is a link to one of our conversation on post:
http://search.netscape.com/ns/boomf...NSCPTop&remove_url=http://www.turbobuick.com/
Look about halfway down page, his logon name is "whiteyz" , again he has a 85 turbo Buick engine with TH325-4L transmission, I think he lives out that way
