Guys and gals a bit of help please,
86 T-type.
Car was running fine a couple days ago. I got on it passing a car on the freeway, one time it was fine, next time I heard a bit of a popping in the exhaust just as I began to enter boost. Now that is all I get, right as I should be starting to spool and build boost, I hear a little popping through the exaust and it doesn't spool.
If I push it, it will build boost erratically and if I really push it it will backfire. I have a scanmaster, but I'm pretty new to the car so i'm not sure what I should be looking for on it.
When not in boost the car behaves very nicely, it idles smooth and accelerates smooth up until about 40% throttle when it should be beginning to enter boost. I pulled the intake pipe and the turbo feels ok, it spins smoothly and doesn't seem to have any play in the shaft.
I really dont know where to start with it, please keep in mind that I'm pretty new to Turbo Buicks, so I might need a bit of babysitting. Right now I'm thinking electrical (MAF, crank sensor, coil), but that it doesnt build boost properly really has me worried.
Help appreciated.
86 T-type.
Help appreciated.
