- Feb 18, 2006
wile2k said:Thanks for the advice, I have now checked the plugs (broke one so I replaced them all to be safe), wires are new magnacores, coil and ignition I dont have spares of to test...
I have checked the IC hoses and they look good, cant get to the IC until I get home (at my Grandparents now). Fuel seems ok.
It runs just fine at part throttle, whether cold start or hot, the problem seems independent of temperature.
Yeah, I'll keep checking the small stuff until only the hard stuff is left, wouldn't do to change the cam or head gasket and get it all back together to only have the same problem lol.
Bottom line for tonight is that under light load and idle the BLMs are 110, when I get over about 1/3-1/2 throttle or about 95 on the L8 load indicator on the scanmaster the BLMs go through the roof into the 144 range. It seems like as I get to that breakpoint there is a miss which is causing it to read lean and run poorly.
Any other ideas given those symptoms?
Plugs all looked the same? Where any of them dark?
The way to check the cam is pull the valve covers and unhook the plug on the side of the coil/module. Unhooking the coil so car won't start. Now you have someone turn the motor over and whach the rocker arms. If you have a flat lobe on the cam you will have a rocker that is not moving like the others.
No guessing here, it will be quite obvious. Good Luck
One other thing. I really don't think it's the IC or hoses leaking because your bl would drop not raise in that condition and it would'nt miss just bog.
