Noob question....
A picture would help . Ha!
'87 GN 58K miles (rebuilt engine by Don Cruz at 47K), 6262 Billet Precision Turbo, Precision 60 lbs injectors, 206/210 Revolution X Roller Cam, Comp Roller lifters, Champion Iron Heads, Champion Ported Intake, T&D 1.65 Roller Rockers, 70 mm Hemco Upper Intake, 70 mm Acufab TB, PTC 10" TC 2800 Stall w/LU, Razor's Kit, ESP FMIC, B & M Shift kit, 3" GN1 DP w/46mm external wastegate, 2 3/4" Dual Magna flow exhaust, ATR Headers, 3.5" Kirbans Aluminium Driveshaft, Eibach Pro Kit Springs, Bilstein Shocks, Spohn Boxed Rear Lowers, Spohn Rear Uppers, SD2 Chip, XP Plus Fuel Pump w/hotwire, Turbonetics Boost Controller, Scanmaster, Powerlogger, Hurst Line Lock, MT ET Streets 255/50-16
Damn my phone didn't load it haha
There we go it loaded now
Ha ha. Now my phone won't keep it loaded. Looks like boost solenoid.
That's what I assumed since it was right behind the turbo.. But as long as I can remember it's never had a hose connected to it? Does it play a main function in how these cars perform? Or is just like a check solenoid for the dash or something?
Depends on your setup. I don't use one but I have an external wastegate. If you have a stock set up with internal wastegate and a wastegate actuator then you need it. It's nothing more than a "switch" that allows air bled from the turbo to reach the actuator thereby moving the wastegate. The ECM controls it which varies the amount the wastegate moves.
