Nordskog Digital Gauges
87GNcospg
Send your Donations
when i first purchased the car, it already had 3 Nordskog digital gauges. water temp, oil pressure, and volts. i added nordskog boost and fuel pressure gauges in the a-pillar. anyone else use these gauges? also, fuel psi should drop if i pop the vacuum line off correct? sometimes it stays right at 43 with that line off and i can adjust the fuel pressure all day long and never get it exactly where i would like it to be. is setting the fuel psi usually a little difficult to get it where you want it? i can sometimes turn a full complete turn on the AFPR and the psi will be that same. it may just be the gauge too.
nord skog (junk)
I had that **** when it was cyberdyne its all **** I tell you **** so get rid of it like a bad case of the clapp! Buy ultra light autometer gauges.
can you say why they are *****. i know they are not the best gauges but the car already had 3 in them so i pretty much had to "match" the other two gauges.
