m233roller
Banned
- Jan 25, 2002
These are Brand New NOS GM parts and all are in Excellent shape.
Both door weather stripping in the GM bags. $350
Both front bumper fillers in the GM boxes. $250
Complete Turbo - T gray horn cap. $150
Complete GN horn cap. $200
Complete (all 9 pieces) gray, burgundy or tan shift handles. $100 each.
4 pull strap screw covers. In GM bags. $50 for a set of 4.
Right side black marker light. $65
Right side amber park light. $45
Black wiper blades in the GM packages. $50 a pair.
3.8 SFI Turbo hood emblems. $75 a pair.
Buick grille emblem. $50
One GN badge. $75
Turbo -T badges. $75 a pair.
GNX supplement manual. $250
GNX badge. $50
Round dome light lens. In the GM bag. Part # 20013679 $15
4 TTA wheel center caps with the metal retaining clips and medallions. $100 for the set.
New gray brake switch. $75
Accumulator Bowl. Has the yellow silk screen. $250
A/C delco ignition module, Part # 24503624 $200
A/C delco coil pack, Part # D552 and # 12353801 $100
A/C delco fuel filters, Part # GF652 $15 each.
Original rad.overflow tank caps. $10 each
Brand new rebuilt alt for 86-87 cars. $100
I have just about any sensor you need just ask.
NICE !! Used Parts
0- Tested & known good accumulator bowl with the yellow silk screen (NICE) $85
1- Heater hard lines. Been sandblasted and painted gloss black (NOT all rusty) $45
2-Very nice hot air car oil fill tube & cap. $25
3- Front license plate mount. Has been sandblasted and painted gloss black. $15
4- Complete and NICE 86-87 air filter set up. $75
5- Nice console ash tray. $35
6-A Cig. lighter never used (like new) $35
6-B Two TTA used center caps . Excellent shape and NO broken tabs. $50 for the pair.
7- Excellent gray, burgundy or dark blue 3rd brake lights. $25 each
8- Set of burgundy front harness belts (harness belts only) alittle edge fraying but still pretty nice belts. $45
9- Complete set of gray or burgundy rear seat belts that are in excellent shape. $75 for the gray set ad $50 for the burgundy set.
10- Like new wastegate solenoid.$45 Less than 300 miles.
11- Like new TPS sensor. $45 Less than 300 miles.
12- Very nice stock adjustable wastegate actuator. Painted black. $45
13- Like new 86-87 wastegate solenoid. $45
14- Limited quarter panel emblems. $25 a set of two.
15- Have all colors of seat belt buckle covers and the B-pillar bolt triangle covers. $5 each
16-A Nice burgundy or gray arm rest. $25 a pair.
16-B Very nice complete set of front dark blue seat belts. $100
17- Gray, burgundy or blue A-pillar molds for hardtop car. $35 a pair.
18- Nice stock up pipes. $25 each
19- 14 inch K&N cone filters with minor rub mark from a/c lines. they are the 3in. NOT all bent and beat up. $25 each
20- Excellent pair of intercooled badges. $50 for the pair.
21- Excellent GN fender or trunk badge. $45
22- Two GN badges with some discoloring on the Turbo 6 logo part. $25 each.
23- Perfect 86-87 vacuum block with new gasket and bolts. $20
25- Excellent cam sensor with cap. $75
26- Known good coil pack & ignition module. $100
27-A Nice stock intercooler. $50
27- Nice intercooler fan. $35
28- Both stock intercooler brackets. $45 for both.
29- H/D wastegate actuator (very little use) $50
30- Lower crank hub and pulley. $45
31- 86-87 ECM and tested good. $50
32-Ignition module mounting plate. $25
33- Front or rear alt. brackets $35 each
34- Right side black marker light (like new) $35
35- Very nice stock electric fan set up. $75
36- Nice (NOT all dented up) 86-87 crossover pipe. Has been sandblasted & painted black with VHT Hi-Temp paint. $50
37- 3in. Black maf pipe. Is scratched up but no dents. $35
38- Low mile & like new 237 FPR. $25 SOLD
38- Nice original inside mirrors. $15
39- Power seat side trim panel in gray with correct 8 pin switch and harness. $75
40- Rear speaker mounts. $15 for the pair.
41- Two complete gray horn caps with the red T medallion. I've repaired one that had the usual crack on just one side & is hard to even tell it was repaired. The other one has some fading on the outer ring. $50 each.
42- Nice 86-87 oil fill caps. $25 each.
43- Nice burgundy, tan or dark blue pull straps. $25 a pair.
44- Stock size chrome up pipe with alky hole drilled down low on it. Looks new. $45
45- Excellent front balancer. $75
46- Nice turbo mounting bracket. $45
47- Two very nice stock low mile throttle body's (no linkage) $45 each.
48- Gray brake switch used fro less than 300 miles, known good. $25
50- Excellent 86-87 oil fill tube and cap. $45
All PARTS are PLUS SHIPPING & 3% if paypaling.
Have pics. of any parts (send me your email address for pics.
Thanks Mike
