I need some help. Perhaps Hartline or one of the other tuners out there could spare me a moment. I have a TT V8 project & I would like to use nitrous for spool up only. I'm working with a B to B fast system I'm wondering if & how I could use the FAST to trigger the solenoids using the trans brake & RPM signal to shut it off just before it hits the two step rev limiter set to 5000. I don't want it banging the rev limiter & injecting nitrous at the same time for fear of blowing the intake manifold apart.I suppose I could use an external momentary switch to activate it manually but seems a bit primitive as opposed to allowing the ECU to do that for me. Instructions seem a bit vague. Any suggestions would be appreciated. Regards Lou
