not a good looking cam
crazygn
10's here i come
I pulled my cam , its bad for sure. I bought a comps cam 206 the lobes on the new cam are about 1/8 to 1/4 bigger then the bad old cam. I used my timer with the bad cam not tuned a broken motor mount and pump gas with 93 chip it said it ran a 14.07 at 104mph that is speening bad in 1st. With my new cam and lifters a good tune and 110 chip could it hit the 12s at a higher boost . The 14.07 was with 15-16 psi and no scan tool.I forgot my main seal was gone not even one in it.The inside of the seal was on the timing chain.
wish me luck putting it back together
I went through the same thing a month ago. Pulled the cam and I had 5 wiped lobes the majority of them where round. I was a totally different car after I installed the new cam. You might want to drop the oil pan and clean the pick up tube etc. Good luck.
Dave85
