Not engaging
NorCalTurbos
Slowing down to SPEED UP!!!
:banghead: This is the point where I wanna go to the shop Fresh rebuild on motor trans was fine now that I got everything hooked up it won't go into gear stock trans with 2500 stall :bookworm:
The obvious: Fluid level where it should be? Converter bolted up? Linkage hooked up correctly?
Not so obvious: Ft pump is fubar. [You broke it when you put the trans on the engine.] The rebuild has issues.
A quiky test: Check the fluid level, KOEO. Start the engine. Fluid level go down to approx full mark?
Yes: Pump is working. No: Take it back out, and find out why.
More detailed test: Hook up a psi gauge, and run thru the tests.
Thanks bro, today I checked around making sure everything is good and I noticed the torque converter is loose so I'm gonna start there your advice was. Helpful
Loose, as in no bolts at the flywheel?? Or, bolts there, but not tite?
There/not tite will make noise.
No bolts present will be the obvious!!:D
No bolts in it I put the block and trans in years ago I guess I forgot to put them in when I recently finished working on it
I guess I'm just a dumbass lol(y):cigar: Now I can sleep again thanks dawg everything shoul be fine once it's bolted to the flywheel
Problem solved bolted up the tc and it was fine thanks for your time and info
