I have an LT1 I just dropped into my car, and am running it with DFI. Now the problem is that I *just* put in a new cam and replaced the cat with a test pipe. Now when I drive the car. there's a metallic sound that I can't tell if it's the motor pinging, or just exhaust running through the test pipe. I just finished putting in a CCXE 230/236 cam and am using a timing map that never went above 40 degrees in any field, and most timing was around 30 degrees total timing, which I understand is a little low for an LT1 anyway. But what really bothers me is that the metallic exhaust sound seems to quiet when I set the timing to 25 degrees in all fields...but the motor does feel a little more sluggish responding, but still makes good power. I'm not running lean (around 13.5 to 1 or less at all times it looks like) and I run 93 octane fuel. Should I not worry about the metallic noise, and just possibly accept that it just may be the test pipe causing the new noise, and not pinging?
Another question, If I give it to shop like Cartek to dyno tune my car, will they be able to do it without the knock sensor? I mean Ford's don't run a knock sensor so it shouldn't be a big deal then right?
