Yes pics!
I concur with what everyone above has said.
And from the initial pics, it looks like you got a decent deal on this car.
Ok, here we go. I see more clues.
Clue 1.
That valve on the passengers side of the upper plenum, with a zip tied and pinched vacuum line, is a home made boost control valve. I would remove that and run a hose from the turbo to the wastegate actuator. This is called tuner style. Re-adjust the actuator rod (IE: make it longer) so there's just enough pretension to keep the valve closed against the turbine housing of the turbo when the rod is attached to the swing valve. Depending if that is a standard spring wastegate actuator, or a heavy duty actuator will determine your base, aka default boost when running a single vacuum hose to the actuator. If you do this and your boost hits 11-13psi, it's a very good chance it is a stock style, standard spring wastegate actuator, which is good at this point. If the boost hits 18-19psi with the single vacuum hose arrangement aka tuner style, it's a heavy duty wastegate actuator and the boost won't go below that setting. Not the best if you are just starting from scratch. Also, when you adjust the wastegate actuator rod, you will see the tiny E clip, or what some of us like to call the Oh Jesus clip. You know, when you try to take it off and it goes flying across the garage never to be found again... A simple alligator test clip is your best friend. It will make for simpler boost adjustments when you start tuning for real. Some people fab up a lanyard and attach it to either the rod, or a close unused bolt hole so it won't get lost.
Clue 2. I see the light blue / turqoise band on one of the injectors. Chances are those are 009, IE: 42.5# injectors. The label on the chip will verify what size the injectors are. That's my best Jedi guess. Just for giggles, here is what a Caspers Ultrachip looks like. This is the one I just took off my car and recently sold. You can see the double button adjuster that this 8 position chip had. (settings 0 - 7) The Maximum Effort chip will look similar, but with your style thumb wheel adjuster and of course a different label.
Clue #3. Looking at your TPS, it has the secondary male to female weather pack adapter harness that either a TPS Tech, or a Caspers V-bolt volt booster has. You will see the TPS harness adapter circled in red.
Is there a small square module that looks like this buried in the wiring harness, in a similar location as the next pic?
Volt booster module circled in red.
If it does, that is a very good thing and something you want to keep on the car. While we're talking about voltage, what is your voltage at hot idle? Typically stock cars will have 13.5 -14.0v at a hot idle. If low, that needs to be addressed asap. These engines must have 13 - 14v under WOT to live. Very critical.
Clue 4. Your turbo oil drain gasket is leaking. That's where the oil and gunk build up is coming from. The fans blow it everywhere when it drips and causes a mess. A replacement is only $3 - $4. I would recommend replacing the gasket and using copper high temp RTV on both sides of the new gasket. Don't just smear RTV on the outside of that gasket and oil drain, it won't cure and will still leak.
Clue 5. The PCV valve looks suspect. Check to see if it's a gummed up stock style PCV, or if it's a brass check valve that's gummed up.
http://www.kirbanperformance.com/product/43791/AFTERMARKET+PCV+VALVE+#7276.html
Or this check valve.
http://www.kirbanperformance.com/product/43836/REPLACEMENT+HEAVY-DUTY+PCV+VALVE+#7302.html
Clue 6.
That looks to be the stock, factory original ignition module and coil pack, as the ignition module is black and the coil pack has the stock white Turbo V6 sticker on it. I would highly recommend putting that on the replacement list asap. IE: the whole C3I piece. (Computer Controlled Coil Ignition is the coil pack and ignition module) Highway Stars has the hook up on those. You'll need a coil pack, ignition module, the gasket that goes between them and the 6 torx screws. They're not cheap, but a worthy must have upgrade, over the 30 year old pieces. I would also go ahead and replace those spark plug wires while you're at it. I recommend Kirbans High Performance gray wires, or the OEM reproduction style that Highway Stars sells. Change out the plugs as well. I recommend either AC Delco R43TS or Autolite #23's. Gap them at .028 - .030 and you should be good for boost levels under 22 psi.
http://www.highwaystars.net/coil-pack-acdelco-12353801/
http://www.highwaystars.net/gasket-coil-pack-gm-25526450/
http://www.highwaystars.net/module-ignition-control-acdelco-replaces-24503624/
http://www.highwaystars.net/screws-oe-coil-pack-mounting/
Clue 7.
You have a worm style clamp that looks like it is digging into the heater core control valve on the back passengers side of the intake. The valve has a vacuum line attached. I would check to see if the wear has gotten bad enough to let coolant leak out of the valve. If not, just readjusting that worm clamp would be advised for preventive maintenance.
I concur about changing out all of the rubber hoses, especially the turbo and intercooler hoses. The one on the t-body to intercooler up pipe looks hard as a bolder. It's not long before it blows off or develops cracks. All of the vendors on this site sell replacement hoses and clamps, both regular and t-bolt style clamps.
And lastly, the entire engine needs a through pressure washing / degreasing. I would highly suggest that if you do, that you wrap and protect all of the weather pack and exposed electrical connectors with zip lock bags and tape. Anywhere water can get, it will when you pressure wash / degrease an engine / engine bay. Don't forget the passengers side inner fender relays, MAP sensor and ESC module, as well as the replays on the drivers side inner fender. The alternator and coil pack / ignition module needs protection as well. There is also the cam sensor and crank sensor that I would avoid spraying down excessively.
Give us more engine bay pics. The more the better. And don't forget that oil change with ZDDPlus additive. One last biggie, stay away from FRAM oil filters. Those are killers. I recommend K&N, Mobil 1 or AC Delco filters. If AC Delco, go with a PF52, vs the smaller PF47. More capacity and filtration.
I am curious to see what the back of the alternator looks like. That will give us a clue if the car has a hot wire kit or not.
Again see circle in red in this pic.
Keep us posted and hope some of this helps.
-Patrick-
