Something I should have been looking at before. Noticed on some recent TLink files that TCC is not locking up until after the run, when Ive already let off the pedal. I was trapping at close to 103mph and the TCC solenoid would kick in at about 107 then turn back off a few mph later (about 103). I throw it into OD after going through the traps. Im using a Joe Lubrandt street chip. Thinking it should be an easy fix if anything is wrong at all, just need some advice as how I should proceed. This will free up some more mph, right?
I know there is plenty of info here about the TCC, I checked, but primarily seem to have to do with either problems locking all the time or not locking at all. Mine seems to work fine during normal driving, so Im more concerned about it from a performance stand point. Need to know, does the way its operating sound normal and I just need to install a manual switch? If so, I cant seem to see any consensus on how to operate it. I have been told to flip the switch when staging, which is also how the instructions (for the switch) at gnttype.org read. I have also seen where it is recommended to flip it when going into third gear.
Any help is appreciated.
