nozzle leak
shawnz
When i push my test button i get a small leak on the outside of the uppipe at the nozzle.Just wondering if i can use clear rtv or devcon thanks John
No. You have to fix it correctly. Get a new nozzle assembly or tighten down the one you have.
Agreed. Went through this myself on my install as I installed my nozzle in a cast-aluminum spot where the metal is pretty thick. RTV's will not work for this -- it needs to have a mechanical seal by way of the crush washers that Julio provides. Don't try anything else other than that and make sure it's leak-free, on both sides of the nozzle, prior to running it hard!
B
