nozzle placement
turbo buicks
ESADAH!!!
i have a up pipe w/an alky nozzle mounted right by the TB. other systems mount them on the inside middle of the up pipe. what is the best location to mount the nozzle in?
also can you burn a valve on a TR running an open dump pipe?
You wont burn a valve on a TR with an open dump. Remember you still have the Turbo turbine as a restriction causing a small amount of backpressure
Just make the face of your nozzle is pointing towards the intake charge for better atomization and it really doesnt matter where it is
