FUEL PRESS WITH LINE ON AT IDLE = 40 TO 41 (You want line off reading, fuel pressure seems too high for a stock chip, could be your rich smell)
ANY CLUES OF WHAT THE NEW NUMBERS MEAN BESIDES VAC LEAK SOMEWHERE ?(Not too sure, 133 BLM is much better but could be due to blocking the PCV valve hose. With the PCV valve flowing it would lean a mixture slightly, higher BLM's, since it is unmetered air from the crankcase going into the intake manifold, at least thats how i see it, any others?)
ALSO STILL SMELLS LIKE IT IS RUNNING A LITTLE RICH(Fuel Pressure is too high, line on will be below 38psi normally, is it a stock regulator?)
IM GUESSING THE TPS IS A LITTLE HIGH(.48V is alittle high, .38-.42 is a good range)
ALSO THERE IS INSTUCTIONS ON GNTYPE.ORG THAT SHOWS HOW TO ADJUST TPS AND IAC BUT EVERYTIME I GO THERE I JUST GET A BLANK SCREEN AND CANT GET TO THEM
CAN SOMEONE POST THEM HERE PLEASE ?(IAC:
IAC Reset Procedure
TPS:
Adjusting the TPS Do IAC first, then TPS)
ALSO DOES THE REVING UP SLIGHTLY AND THE BLS DROP TO 128 THEN GO RIGHT BACK TO AROUND 133 OR 134 INDICATE A HEADER LEAK ?(Computer has 16 BLM cells, your just going to a new memory cell when reving, normal)
WHENEVER I DRIVE THE CAR AND PUSH IT TO KICK THE TURBO ON JUST A LITTLE BIT WHEN I LET OFF I HEAR A BUBBLING OR SORRY FARTING SOUND COMEING FROM THE RIGHT FRONT OF THE CAR ?(Normal, especially with an open filter, its just boost coming out of the air filter since it has no wear else to go!)
HTH
