Hi guys, I'm new to this forum... but I can tell that you guys who your stsuff from reading past posts.  From reading past posts I learned that 15.94 is pegged for the wideband O2 sensor....  I have a fast ECU.  My o2 sensor does get hot.. but at idle (I've never had the car on the road so I don't know what it does at cruise, etc.).  I also called the FAST tech help and they said that if none of my O2 parameters showed up in red that means my O2 sensor is OK.  Is that true.  Anyway.. since I've had this car running I have never noticed the computer making an O2 adjustment... I am running in Speed Density and have the O2 enabled box checked.  My O2 correction table is set at +-25 on the lower rows so I was thinking that it should be doing something.  The O2 sensor does not rattle when I shake it (someone said this was a test to perform).  If I do not have a bad sensor the only other thing I can think of is my VE values at idle are set at 30-40.... Could it be that with these values the car runs so lean that it doesn't even try to make a correction...?
Any help you can provide is greatly appreciated..!!! Thanks.
