I'm just looking for some opinions on my readings. I just put in my new TT chip, and at idle my o2's are between 500 and 600. If I crank the fuel pressure they won't go any higher, but if I lower it they drop as I go. The chip is set up for 25 psi, and I had the boost at about 13 psi the readings at full throttle were around 780. It should be running totally rich. The cross counts are cycling from 0 up about every 5 seconds. The chip has the fast sm update. I had similar readings with my Denso and my Delco o2, but they are both from last season. Any ideas? Thanks
