O2 readings?
JAYMBUTLER
what should be the o2 readings be on a 87 gn. mine are real high i think. they are in the 820-850 range. i cant seem to get them any lower. any suggestions would be appreciated. i have lowered the fuel pressure to 38 lbs with the vacuum line off.
What scan tool are you using to read them?
That is pretty high then.
Type of chip, and other particulars of your setup would help.
38 lbs is kind of low depending on your chip. If you have a programmable chip I would set the FPR to 43 and take fuel out using your chip.
