Need some help.Went to the track today and had some poping coming out the dump .Drove to the track, took the dump plate off the terry h down pipe, ran 15 lbs boost on a te 45a(te63) at 40 fuel pressure and ran 13.1 at 109 smoking the hoosers(27.5X11.5 X15)Last week the same set up I ran 112 mh at 12.6.
So I turned the boost up one turn because the o2 were 860 in first and 830 in 2nd gear pull (this is when it started to pop because it's rich then it took a nose dive to 620. So I put the dump back on an ran it .It was slugish so up went the boost.It started to do that again at 18 -20 lb boost on 114 unleaded.I have the 009 with9.5 prec. vig. lockup C.A.S front mount,xp plus pump and hot wire kit.volt booster d.s scan(still learning to use it)and Red.A street and 107 chip.Went out and bought the translator Plus and today I think I need the 75lbs inj.
ANY IDEAS or am I missing something?
Thanks for the help
Big Mike
Thanks for the help
Big Mike
