Originally posted by azgn
actually, the 02 inputs are used everywhere except WOT.....so not much effect when racing other than spool up...if you "learn in" a good 02 with unleaded and change to the bad 02 with leaded...all will be fine unless you unplug the ecm
as stated, the ME doesn't use the 02 at all and no chip uses it at WOT......except maybe a FAST system with a wideband...it does correct at WOT
I believe the T+ and extender can run in open loop also
egt is a better way to tune than 02
