- May 28, 2001
Here's what happens when you don't use the filter socks, and a filter that's too "loose".
These are TFS 120's, Hipo Mustang/w/blower.
The pumps, [2] were put in w/o the socks. The inline filter was 100 micron.
[The owner had the mistaken idea that a 100 micron is a finer filter than a 10.]
Once the car displayed drive-ability issues, a second set of the same injs were installed...With the same result.
Here's a pic of before and after. ALL that was required to get both sets to an OK condition was to pull the filter baskets, replace w/ new, and re-flow test.
Strangely enough, another Moostang had the same issues..More than a couple "hi profile" shops failed to find the issue..Was the same as above!
Also, just did a 3rd set of 120's. These were on E85. Of the 6, 3 worked, w/ 1 being anemic, and a bad pattern.
It took considerable work, and 4 cleanings to resurrect them.
These were in a running engine, and had been out in open air for only a few weeks. It seems this alky dries out really fast.
Had they sat for much longer, I doubt they could have been saved.
