some hot air parts I found.
84 lear siegler sand grey center console plastic bottom lid
3 good bosch 233 regulators
2 good tps sensors
set of spring latches for a stock hydroboost master cyclinder
one used rubber pcv s hose (connects oil tube fill to plastic air intake)
2 stock engine lift hooks I had blasted and painted
1 stock wastegate solenoid that I think may be for a hot air, but not absolutely positve, if not, its for a ic'd car
one good crank sensor with extra bracket (blasted clean)
one brand new never installed 160 degree thermostat and gasket
one valve cover bolt with the metal tab that holds the plug wires in front of the pass valve cover
one additional metal tab with correct factory plastic wire holder clip
one very nice stock air cleaner mount
$50 shipped for the lower 48 only
2 good tps sensors
