OEM brake specs
vacuum 6
Rotors: at what thickness should they be replaced?
Front pads: at what thickness should they be replaced?
Drums: at what diameter should they be replaced?
Rear pads: at what thickness should they be replaced?
When I rotate my tires ,I check my brakes.If you must no the spec an thickness ,on the front pads change them at about 5 millimeters ,an if your rotors have been resurfaced 3 times or more just replace them,rotors are a lot cheaper now than in the pass. On the drum brakes replace at 16th of an inch from pads pivot studs.an on the drum brakes just change them out after 3 resurfacing 7 MM.
