Backstory:
I bought the car, off of a well respected individual. When I got it, the motor would break up when it approached 20lbs of boost. I figured it was blowing the flame out so I changed plugs and dropped the gap to .028". The problem was still there but marginally better. I decided that I "needed" The TR6 ignition so I bought it. I installed the Ignition and the car wouldn't start. The Ignition was throwing a cam alignment code. I set the cam sensor alignment and the car fired right up. I tried to drive it, and this popping stuff started. I re-checked the alignment because I thought maybe I made a mistake and got it 180 out. After resetting the alignment, (which was correct) the problem continues. I pulled a known good MAF out of another car, yet the problem continues. Also to be noted, even when I first got the car, I had to roll into the throttle, I couldn't just jump on it. I am stumped. Any Ideas?
