off idle stumble
UPDATE GENTS!
Ok... so, I found yet another issue. Was cleaning off some motor parts after I removed my TB and noticed some green fluid sitting on the outside of my intake... all collected in the exterior valley on the passenger side. Upon futher inspection, I noticed that it made its way across the intake manifold and into the other valley on the drivers side. I am thinking.... great.... antifreeze. But its not. Its my Brad Penn oil I run in the car (yes, the oil is green). So, here is my question, I am assuming that I am pushing oil under boost because of where I found it along with some spray patterns. The funny thing is, my BLMs dont show a lean condition which would show if I had a vacuum leak. I am having the opposite effect in the BLMs being low...
I know that turbo cars are suseptible to pushing oil under boost so is this something I should worry about? I can change the intake gasket but its a tedious process because of how my turbo and all necessary hot and cold side pipes are oriented.
Your thoughts fellow TB peeps?
Chris
Chris sorry for the delay, i've been sick. I have two maf screens that you can have if you still need them.
Yes, I have both screens and the lock ring. Mine is cracked but it doesn't matter.
Sent from my Droid using Turbo Buick
Ok. I live in Jeannette. Probably not heading up there but I can let u know for sure tomorrow. I do have family that lives up there though. Is it Buick night up there tomorrow? Gonna send u my cell number thru PM.
