I vote for no changes.
-Weights are good as seen by the two top performing cars at BG..(within .1-.15 ET avg)
I've run both 71 turbo @ 3450 and 67 turbo @ 3350 to prove that point. Identical times with both combos (8.81 BG 2012 - 8.81 BG 2013)
John Plog went 8.96 with a big wheelie with irons at ~3260, little less wheelie and it will be 8.80-8.90 range.
Walt J went 9.20s, Randy A has been 9.20s, etc at heavier weight.
-Exhaust removal, wastegate changes, or 4 bolt turbos will increase power... alot..
IT WILL make cars faster than they are now.
Keep full exhaust and wastgate into DP
Keep three bolt Buick style housing rule to limit exhaust wheel size
-The "Turbo Plug" was supposed to be shipped back to me from Sully but I still haven't seen it. I do have the rings for the 71/67 compressor wheels if needed.
The only limit we have right now in the class is the exhaust housing/wheel combination. Remove that, you remove BP and make more HP..
I've tested so many different things to prove to myself that the rules/weights are pretty dang close, and they are..
That's my opinion based on facts, Carry on.
Sack thanks for leading this discussion... I told you what would happen
FYI if you want your fastest time updated PLEASE email timeslip info to
turbostreetmodified @ gmail.com
