Offset- Improvising?
jake616
I have been thinking of purchasing a set of wheels (17x8,29mm offset,5x4.5) but I was not sure how I could get them to fit correctly on my Probe.
The Probe: The lowest offset that I know of on a probe is 32mm. (this requires cutting the spring perches and possibly rolling the fender wells based on tire size~you would need coil overs more than likely) The highest offset that I know people run on the probe is a 50mm. (now with that offset 3mm spacers are need on the rear) So basically, anything between 32mm & 50mm will fit. It all depends on where you want the wheel sitting.
I can fit up to 19's on so that measurement is fine.
Can I get these wheels to work?
What will the problems be?
