Jan Larsson
- Nov 22, 2001
Chasing some sort of very light oil leak ... getting oil splatter from one of the pulleys and it seems like the AC pulley is getting some light oil on it that is then splashed around my engine bay (1989 TTA).
Splash pattern on hood insulation then onto the driver side engine bay area perfectly in-line with the edge of the AC pulley.
Have had this for some time (car driven very little); AC Compressor replaced and everything re-charged 4 years ago ... this started to happen maybe 3 years ago ... AC is still blowing cold so not sure if it's the AC compressor or not.
Been checking AC compressor and can not feel or see any leaks on the AC Compressor housing. Same with the PS pump and hoses (new unit when I had the engine rebuilt back in 2006) ... just checked the pressure hoses today and they are all tight and can't see any oil weep anywhere.
Cleaned everything up (again) and took it for a 20 min drive and sure enough again oil splatter and the front edge of the AC compressor pulley have some very light oil residue on it ..
Did not run the AC at all today ... could the AC compressor seep some oil out up front on the clutch? And if so would I also loose refrigerant or not?
Not happy driving the car with the risk of a pulley seizing and causing some major damage / issues so any help / advice / pointers much appreciated.
