vacuum 6
- Jan 6, 2006
Does anyone have experience with them?
Can you use the factory oil cooler adapter for hookup?
SignUp Now!You need to pressurize the accumulator with air. See the air valve next to the gauge? The electronic valve on the other end captures the oil and holds it under pressure. I would shut the electric valve off with a switch in the car when the oil pressure is up.
Then the next time you go to start the car, turn on the ignition and before starting just flip the switch and the captured oil will lube the motor. You can see it working on your oil pressure gauge. When the pressure gets low just start the car. If you leave the switch on you also have a little oil pressure reserve if you stand the car on the back bumper or throw it hard into a turn. Probably not really necessary to have but the manufacturer is right down the street from me and I am a dealer for them. Had a kit on my site for a while but never sold a one to a Buick owner.![]()
I tried to look up your post but it didn't come up.If you check out my thread you can read how I installed this oil accumulator system and also the web site that carry this system. If you have any question email me. Julio
http://www.turbobuick.com/forums/threads/pre-lube-system-installed.313903/
This thread is almost 5 years old,the board got changed and rearranged since then,so none of the old links work.Here is the link you were looking for http://www.turbobuick.com/forums/threads/pre-lube-system-installed.313903/I tried to look up your post but it didn't come up.
TyThis thread is almost 5 years old,the board got changed and rearranged since then,so none of the old links work.Here is the link you were looking for http://www.turbobuick.com/forums/threads/pre-lube-system-installed.313903/
I know it looks the same, but try this one since it did open for me, and if not then what type of computer internet service system you're using?
A board admin changed it,it was this old link http://www.turbobuick.com/forums/engine-tech/313903-pre-lube-system-installed.htmlI know it looks the same, but try this one since it did open for me, and if not then what type of computer internet service system you're using?
http://turbobuick.com/forums/threads/pre-lube-system-installed.313903/
I knew about the board upgraded the site, and the Web Master has also added many past threaded info including mine. I have no problem going into mine thread of the per-lube system.A board admin changed it,it was this old link http://www.turbobuick.com/forums/engine-tech/313903-pre-lube-system-installed.html
