Just a quick question and I am sure someone will be able to give me a straight answer.
Beofre 2.05 when we logged oil and fuel pressure sensors we had to calibrate them into one of our 8 analog sensors.
With 2.05, the fuel and oil are under system config-->sensor calibration.
Now I inderstand the fuel and oil must go into the Analog inputs 1 and 2, AND are calibrated within system config now.
So when it comes to logging these specific sensors, should I just use the Oil Pres. (PSI) [ which is from the system config side of things] or should I use the Oil PSI ( which is from the analog input side of things).
The numbers are really close, but it is nice to only have what you need in the dashboard and more importantly logging only what you need.
Attached is a photo :
