oil change questions
fastforded
1. wondered what type/weight oil i should get? (already have the add plus zinc additive)
2. what make/model oil filter should i use?
3. oil pan drain bolts? 1 or 2? and where are they?
thanks, any info/thoughts appreciated
Just a warning, some people on this board are going to throw a shit fit over this question because it gets asked so often. Please use the search option and you will get many answers to your question. My answers are...Is your motor stock, use regular oil like any 10w30/40. I have a built motor and I follow the builder's advice and use 20w50. My filter preference in Wix/Napa Gold filters, although this year I am using the K&P Engineering filter I got from arizonagn.com. As far as I know, there is only one drain bolt and it's on the bottom of the oil pan. I use a bolt that has a magnet on the end of it...hope this helps.
I agree with everything posted above. I run a 10/40 dino oil and add a bottle of zinc each oil change and yes I have a roller motor.
I change oil every 1500 miles or so.
