oil path from the pump
into the block where the oil sending unit is--from there up to the drivers side oil galley--from there some oil goes to the front cam bearing--around bearing and into the drivers side galley ( a small amount goes into camshaft and out to the front of cam to lube the cam sensor drive)---along the oil galley to lube drivers side lifters. Now back to pass. side--that oil goes along the galley feeding pass. side lifters and @ each main bearing spot there is a drilled hole from galley to main bearings---feeds mains which in turn feed rod bearings. Front main feeds 1 rod--2 and 3 each feed 2 and # 4 feeds the remaning 1 rod. Clear as mud????? I may have missed some small detail and if I did I'm sure I will be corrected.
