Oil cooler adapter plate?
calais1965
Whitch one of these two oil feed lines at adapter plate are inlet (hot side) to motor oil cooler?
I want to know because i want to get my turbo feed from cold side of adaptor plate.
Your turbo feed comes off your oil pressure switch off the side of the block. The T brass fitting.
the 'cold' side is the fitting that's is on the filter side of the sammich adapter.
I am not going to use fitting from block.
I will duplicate fitting from colder side of cooler line , attach turbo saver filter and use for turbo feed..
It's not a big job. Just remove the sammich adapter then drill and tap whatever fitting you want to screw into it.
