Mar 4, 2018 #2 1KWIKSIX Well-Known Member Joined Sep 29, 2007 Messages 3,210 install studs instead....you won't regret it. Trust me.
Mar 4, 2018 #3 J Jared31 Active Member Joined May 8, 2015 Messages 453 1KWIKSIX said: install studs instead....you won't regret it. Trust me. Click to expand... What size studs
Mar 5, 2018 #4 1KWIKSIX Well-Known Member Joined Sep 29, 2007 Messages 3,210 Jared31 said: What size studs Click to expand... Believe the bolts should be M8 x 1.25, you'd want the studs long enough to have enough threads for a nut and lock washer.
Mar 5, 2018 #5 J Jared31 Active Member Joined May 8, 2015 Messages 453 1KWIKSIX said: Believe the bolts should be M8 x 1.25, you'd want the studs long enough to have enough threads for a nut and lock washer. Click to expand... Thankyou
