I've always used Wix or Napa Gold but I was always curious to know many microns does the 51036 and 51036xp filters down to respectively? Seems you're the perfect person to ask
.[/QUOTE ]
The short answer is I don't know what "micron" rating this particular part number is because we use a Beta Ratio to rate this filter's efficiency. Without getting overly technical, "Micron rating" is a terrible measurement of how good a filter its. Most premium filter manufactures use what is called Beta ratio to calculate the filter's efficiency. There is no industry standard on micron ratings, therefore, filter manufactures can pretty much give their filters whatever micron rating they want if it stops just one particle of X size. On the other hand, beta ratio ratings involve introducing a known number of many particles of X size to a filter, then compares the number of downstream particles to determine a beta ratio. This give you a filter "efficiency" of X size particle.
The important thing to understand is that particle filtration and oil flow are a trade off. In all filters including fuel and air. Much like a K&N air filter is great at flowing air but are terrible at trapping dirt, our racing oil filters are high flow and allow oil pressure and volume to be priority . They put all emphasis on oil flow to the engine bearings, but don't filter particles all that well. Most race engines are very clean and normally have the oil changed at very short intervals so particle filtration is not a huge deal.
All filters become more efficient at filtering particles once they begin to get dirty, because smaller particles start to be trapped in a filter loaded with other particles. But the pressure differential becomes high and flow suffers. Our Wix XP filters are designed to flow and filter particles well. They become efficient over time, but start off as a very high flowing filter. This is good in a high performance application where oil flow is important, or in an application where someone might want to go 10 or 15k miles between oil changes. But if you want the best particle filtration, just stick with one of our premium filters (Wix or Napa Gold) like you are using.
