oil &h2o senders
For my mechanical pickups I assembled "T" fittings. For the water it is in the bypass hose off the back of the water pump, and for the oil it is under the turbo on the side of the block - just follow the oil supply line to the top of the turbo.
you put your sending unit behind the turbo with a t fitting ? i was thinking about using the one where the oil sending unit is but i couldnt find a fitting that big i wanted to put a t in there but couldnt find a fitting that big
Nothing behind the turbo.
