Just wanting some feedback on why I have some oil in the innercooler. I have a stock turbo that has been functioning fine as far as I know but I have an opportunity to upgrade to a larger turbo. I found oil on the bottom side of the upper inlet that had not been there before but has appeared since I installed an alky injection system. I believe I made have early on mixed to much lubricant in the alky and was wondering if this oil could possibly be from the alky injection or bad seals in the stock turbo. When disconnecting the innercooler from the turbo there was no sign of an oil leak, there was alot of oil on the bottom end of the upper inlet pipe coming from the inner cooler. Any thoughts on this?
