Yesterday when I checked the oil it was @ 1 quart low. I then noticed oil in the coolant overflow tank. After talking with local Buick buddies the determination was that either the oil cooler in the Rad. is leaking or the front cover gasket went bad. I flushed the Rad. and changed the oil and disconnected the oil cooler. I pressure tested the rad. to see if coolant would come out the oil cooler holes but nothing was confirmed. I drove the car yesterday and again some more today, at times quite hard, and have yet to see anymore oil loss or presence of oil in the Rad. or overflow. My fingers are crossed. Anywho I decided to do a search here and see if anybody else had ever expierienced this and could not find anything. The only thing I did find was thaty some people had stated that if you had oil in the coolant or coolant in the oil (which I did not have) then it could be a blown head gasket. So could it be a blown headgasket if you get oil in the radiator, and if so how, since there are not any oil passages next to coolant passages on the head gasket?
Any info supplied would be helpfull since next week I plan on taking the car to Ocean City for the a week and I am certain I will be putting a beating on it.
TIA
TIA
